Pipe Bending
I was hasty in posting - and take it all back.1/2" Rigid Conduit (GRS) is probably a closer match (to 7/8" S/S) at 0.80" O.D. and 0.218" wall thickness. The stainless, though thinner, will be harder than mild steel conduit.Also - recalling my days (25-30 years ago) as an expert conduit bender - it wasn't really all that easy becoming proficient at GOOD bending.I THINK, that having had to ask, YOU PROBABLY WILL NOT BE ABLE TO BEND UP AN ATTRACTIVE & FUNCTIONAL PULPIT. See Robert Taylor's post.S/S tubing @ 7/8" O.D. (0.875") with 0.069" wall thickness is not exactly analogous to Electrical EMT Conduit (nearest size is 3/4" @ 0.922 O.D. & 0.049" thick), but close enough, if you are very careful to keep good pressure on the bender (foot pedal) with your foot when making the bend. The bend will not be even, and the accuracy may be off if the proper foot pressure is not applied.Bending isn't difficult, but getting the right amount of bend, in just the right location can be tricky - and requires some theory and practice. Some helpful references:The Basics of Bending Conduit (parts 1 & 2):http://www.ecmweb.com/mag/electric_basics_bending_conduit_2/ http://www.ecmweb.com/mag/electric_basics_bending_conduit/Conduit Bending Theory:http://www.porcupinepress.com/_bending/TheoryAndDrawings.htmGardner Bender (Bender product & instructions):http://www.gardnerbender.com/whats_new/products/fr_np_Bigben.html
