A very important consideration when choosing a marinaOne thing to remember is always back into the wind.
I've been waiting 3 days to back out of my slipOne thing to remember is always back into the wind. If the wind is coming from the bow it will blow the bow around more than you can offset with the rudder.
...came back after a race (a first and a second, thank you) about 0230 after being gone for five days and found a Whaler in my slip. I backed to a dock and let two of my female crew off to move the boat out. However, that left little room to maneuver. It took two applications of forward and reverse thrust to kick the stern over. At least it gave me something challenging to do rather than grind my teeth and curse about the boat in the slip (misunderstanding about when we would return).Question to the group. How many of you have turned your boat within its own length. Hard over to starboard and forward thrust for a moment then reverse to kill the forward motion and prop walk (again to starboard) then repeat.
I had to do this at Fort Washington on the Potomac right after I learned to sail. I did not want to back out the narrow channel as I had run aground getting in. Lucky i had seen the concept in Chapman's Piloting. It was pretty easy. The good Lord looking out for idiots (again)
You'll find that, with the E32 and its big rudder, you can almost center the rudder and steer a bit when you enter the coasting phase. I tried to make the animation a bit more generally applicable.Roger, that animation is 1st rate and will def. help me when I get the courage to back-up my new-to-me boat.
