How to avoid losing fluids
Steve Paul
I have your book, great. How do I avoid losing fluids when I change my hoses on a Groco manual head?
Trevor - SailboatOwners.com
Get a bucket
It ain't pretty, but you'll feel good about gettin' 're done. Get a paint bucket (or several), a bunch of rags, and pull those hoses. It'll never be a fun job, but you'll feel pretty good about replacing all those hoses when it's done. Best, Trevor
Dec 2, 1997
9,011
- - LIttle Rock
First, make sure the fluids are just water...
Disconnect the head intake hose from the thru-hull and pump several buckets of clean fresh water through the whole system. A quart of vinegar added to the last bucketful will help a lot. Disconnect the highest hose connections first...put plugs in the ends. Put a garbage bag or a disposable aluminum pan (where one will fit) under the other end of each hose to catch the spills. Hoses will come off the fittings a lot easier if you warm 'em with a blow dryer first.
Steve Paul
Got it, thanks
Understand. I'd like to invite Trevor over to do this. If it makes him feel so good, this'll make him ecstatic....:) Steve
