Patrick
While motoring my Cat 27 in Puget Sound, WA, my 5411 (raw water cooled) started to overheat. I closed the recirculation line via an inline ball value, forcing all water overboard thru the exhaust. (Note: I have a 3/8" ID thermostat bypass line). This slowed the temp climb but I had to throttle back to 2/3 to maintain 155 deg. Is this normal? My Oberdorfer pumps about 2.5 quarts per min at 80% throttle. Should there be greater volume or is this around spec? Thanks for the help.
