How much transmission fluid is too much
Bob
I find it very hard to read the transmission dip stick and actually think that mine is overfilled. Are there any harmful effects of having too much transmission fluid?
Jack
Mine too
My 2001 C36 MkII came overfull. My guess was that it was filled when level. Since it was that way from the factory I left it that way and have had no problems in three seasons.
RonD
Reading the stick
Try shining a flashlight at a low angle across the stick. It can help highlight the fluid level.
G
Ghislain Gaumond
Check Stu's...
Bob, Check Stu's helpful advice from Sept 23, 03...in "transmission dead in the water"...most certainly help me learn how to check oil level. Fair winds. Ghislain "Emilie-Jolie" C30, 1987 #4708
Ron
more reading the stick
Here's an idea *! Pull the dip stick then lay it on a paper towel or such. You'll be able be able to see the fluid level exactly by where it wicks on the paper. Ron
