Mike
I'm in the process of removing the bottom paint from my O'day 26. I've been reading a lot of advice on this forum about using a barrier coat on bare gel coat. From what I have read, quite a few coats must be used. Seeing as how the Interlux 2000E costs about $80 a gallon, I was just wondering if anyone has used this stuff on a similiar size boat. How much did you use? Also, did you use a solvent like the Interlux 202? If so, how much was needed? Finally, does the Interlux 2000E work well with West Marine CPP ablative paint? As you can probably tell, money is a bit of an object, but I do want to do the right thing. I definitely don't want to scrape all this sh*t off again next year because I took the cheap route. Thanks.
