How is teak finished in mid-90's Hunters?
764
Hunter 376 Pensacola, FL
I need to do some bulkhead replacement on my 1995 H336, and I want to be able to match the existing color and finish. I know Hunter Marine used Dalys Seafin on the interior teak, and I've already picked up a can, which I've been using for touchups. My question is when starting with unfinished teak, did Hunter use some kind of stain before the Seafin, or can I match the existing finish by just applying Seafin to raw teak?
Dec 2, 1999
15,184
Robert:
I would suggest that you try a small area and see how it looks. My Hunter Vision has a couple of different wood types and I would assume that some were stained and others were not.
Feb 10, 2004
4,232
Hunter 40.5 Warwick, RI
I have added small pieces of teak here and there and have just finished with the Daly's. The match varies as you would expect. I think it depends upon the specific shade of the teak you are finishing.
Perhaps Hunter customer service could tell you more.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
You ask a good question. On my old 91 30T I didn't think the Dalys on new teak was dark enough. I usually used some other brand of teak oil that was a little darker. It seemed to match pretty good. Don't ask what I used as I don't remember. Try a sample first.
