How is rub rail attached
Jun 17, 2014
12
CCS Daysailer 17 NH
I would like to install a new rub rail and I was wondering if SS rivets or screws are recommended?
Aug 3, 2012
2,542
If you look / feel under the deck, you will see how the old one was attached. It was probably screwed into the hull at the joint between the hull and deck. Be sure to seal the joint. I am ambivalent about sealing the rub rail because if you seal it top and bottom, and it leaks on top, the rub rail will then hold water against the hull / deck joint. Those darn things already accumulate so much crap!
Thanks,
Andrew
1,956
Oday Day Sailer Wareham, MA
Well, I'll give you the same usual advice......... call Cape Cod Shipbuilding.
However, I know that they use a special adhesive on their other boats, so perhaps they do the same on the DS IV. I looked on their website but it only lists the price for the rubrail (on the DS Parts List), and the Rub Rail "kit" (I assume that includes screws or glue).
Best advice is to give them a call, or maybe post this question on the DSA web forum, www.daysailer.org
I know that I looked at an older (1973-5?) DS II at D&R that had an added rubrail and it had been attached with sheet-metal screws as best I could tell, although the screws were short enough to just barely stick through the underside of the hull-deck joint. For any non-DS II owners, the hull-deck joint on the DS II is sort-of an outward turned flange that curves over like a plastic bucket rim, the deck edge is bonded over that like the lid of a trash can. See drawing below, I am reasonably sure the CCSB Day Sailers are similar, although the joint is squared off, not rounded.
12
CCS Daysailer 17 NH
Well I used rivets every 6" and closer at the bow. Needed grip ranges from 5/8 all the way up to 1" as the dimension varied. The rub rail I used was semi ridged Vinyl so I used a Heat gun to bend it around the bow. Came out awesome.
Thanks for the drawing Sunbird, yes the construction of mine is very similar
