G
George Fletcher
I was recently at a Hunter rendevous and the Yanmar representative stated the the 4JH, (mine is a turbo), should run at a water temp of 165 degrees.I have had the boat for two years and the temp gauge reads about 175 degrees at 2,800 RPM cruise. At 3,000 RPMs the temp rises a couple of degrees to about 180.It has been this way since day one. The Yanmar service reps in San Diegoc had the boat out at high RPM cruise a year and a half ago because of a complaint on excessive soot on the stern. They made no metion of any abnormal temp indication.They also checked the eng/prop combination and it was found to be correct.Is this a normal indication? Is the wrong thermostat in place or is it defective?Or is my temp guage out of calibration with the thermostat?What to do, if anything?
