How hard to upgrade to pressurized water system
Apr 25, 2015
282
Oday 26 Oscoda, MI
Just starting to replace all my water lines and a foot pump was brought up and then I thought of just adding a water pump and replacing both sink faucets. Anybody do this to their O'Day 26 or any O'Day really? If you did, I am just curious on where you mounted the pump, what pump (how many amps) and what faucets.
And can one stay with vinyl tubing if upgraded to pressurized?
sdstef
Jan 31, 2013
140
Hunter 28 Branched Oak Lake
Very easy. I installed a 23 gallon plastimo water tank. Plumbed it up to a pressure pump with a integral pressure switch, so that when the pressure drops, the pump comes on, like when you open a spigot. I replaced both sink faucets on the boat. You will need to wire the pump and provide a fuse or breaker and a on/off switch. I got all the parts from Defender. Probably 400 bucks for everything. Get the faucets at local big box hardware store and all the hose and fittings too. I do not use it for drinking, so I did not use food grade hose or install any filtration. On my Oday 25 with the outboard, I installed the tank on the floor under the cockpit between the stringers and on a rubber mat where the inboard engine would have been. I installed the pump a few inches away from the tank outlet and below the tank so gravity can prime the pump. On the pump discharge I put a tee in the line so I could feed both faucets. Works very well. Put an on/off switch and always leave it off when away from your boat. If a leak develops the pump will start and eventually when the tank is dry, the pump will soon be ruined.
Ritdog
Jul 18, 2011
184
Oday 25 Portland, ME
OR, you could get an auto windshield washer pump for about $20, and just push the button
