How far back to install a boom vang on a Hunter 25
Bob Pattersen
I, recently, purchased a new book vang for my 1986 Hunter 25.5, and am confused at how far back to position the vang on the boom. Is there some sort of geometric relationship I should be trying to achieve between the distance from the bottom of the boom and the base of the mast? I would appreciate any feedback on this subject before I attempt to drill holes in my boom. Thanks, Bob
Stu Sauer
Boom Vang Connections
Assuming you don't have pre engineered tangs on the boom or at the base of the mast, you will need to create those attachment points without weakening the structural integrity of the mast or boom. Start with a bail attachment at the lowest point of the mast, clear of the deck. On my 1978 Hunter 25 that was a bail added at the thru bolt for the mast base. Look at a boom vang making at least a forty-five degree angle 1:1 with the mast and boom as a minimum, and a longer 2:1 leg out along the boom as more of a maximum. The exact location of the bail out on the boom should consider any other hardware in the immediate vicinity so as not to create a week area in the boom. The third consideration is the purchase you need for the vang, starting with at least a 4:1, assumind a traditional boom vang. Look at other similar boats before you drill any holes and make sure you can engage or disengage the vang in it's cam cleat. If you are considering a 'Yacht Rod' or 'Powervang', these solid vangs are far more expensive; come with their specific boom and mast fitings and eliminate the need for a topping lift. Check out West Marine's Catalog for cost and set-up comparisons.
E
Ed Schenck
Another approach.
Stu gives good advice. My Cherubini has a tang on the bottom of the Kenyon boom. And as Stu says it makes a 45 degree angle with the base of the mast. I pulled out a mast partner bolt and replaced with an eyebolt for the base attachment. But now I wish I had purchased a solid Garhauer vang instead of the rope vang. It does work nicely as a preventer but the topping lift is still a pain in the butt. If you purchase a Garhauer solid vang you get the hardware and installation instructions. Check the Related Link and see how much difference in price between "Boom Vangs" and "Solid Vangs".
Bill O'Donovan
Short answer
Attach the bail to form a perfect triangle.
