OK, for you engineer types (non communications types like me), on the S3213 water separator, how does the water get into the bowl?
Let me say what I think I do know so you can bypass that part and just get to the meat of things. I know the contents pass through the six holes on the top of the filter. Then the contents goes through the filter to the center and it then extracted so it can be used by the motor.
At the bottom of the filter there is a bowl. The fuel fills the center of the bowl but the outer side of the bowl is sealed with gaskets. The bottom of the filter has a plastic floor so I doubt any fuel or water gets into the bowl that way.
Let's hear your theory on how the water gets into the bowl so it can be drained with the drain plug.
Thanks
Thanks
