Keith,hey guys, this question is a little late, but do you wet sand in a circle, like buffing, or with straight line, like in wood sanding.
keith
When I get down to wet sanding it is all by hand. I need to have the feel of what I am doing with the paper. Wet sanding is just opening the surface layer of paint so the next layer will adhere. you should never need to stay on one area long enough for a power sander. You could also take way too much paint off with a power sander. The resulting deep shine comes from it.What about the type of sander and rpm. will a good palm sander do the job with proper grit of paper?
oh ,i see, i missed that post.....i think cirular motion, light massage type pressure, start with 600 them move all the way up to 2000 then start your buffing. I was really impressed with the results. and it was the first time i started. I tried buffing alone, over and over again, but it will not get the shine back if you don't sand first.I think Jack is looking to get elbow deep in sanding right now.
