As RichH described, I also lead my furling line through a hexaratchet block block. For me it's at the toe rail right next to my helm. The lead angle is just perfect for pulling in or letting out. When letting out the sail, and also if I need to furler reef in when sailing, the hexaratchet prevents possible uncontrolled run-out of the furling line.
Contrary to advice never to use a winch :naughty: -- I do :dance::dance:.
But only to maintain control of the rolling up process as a solo sailor. I do not allow any real strain/tension on the furling line. Not any more than one person hauling in on it while another other slackens the jib-sheet. The prevailing wind direction (usually strong) when I am returning to berth allows my furling line side primary self-tailing winch to be free. I wrap the furling line around it. The jib is still sheeted around the winch on the other side. I disengage the sheet from the self-tailer jaws and hold the sheet in my hand. As I winch in on the furling line, I slack off the other side jib sheet as needed as the furling line is pulled in. As the exposed jib sail area reduces after a few wraps, I can throw off the jib sheet from the winch and finished easing out by hand tension only. Again, even though I am using a winch on the furling line, I don't allow any real tension on it. The jib is allowed to bellow-out on the jib sheet side. Not per traditional protocol, but I find the winch adds control and safety from flogging in high winds during the furling-in process.
