One of the issues I want to fix is to prevent the swing keel from banging side to side when it's down. Have any of you fixed this before?
The rubber piece is the "stop" so if you let the keel down too far (or the cable breaks)it won't come crashing through the trunk. Alot of the clunking is actuallly from the pivot hole hole being worn, which lets the keel "twist" around. My 25's keel was slapping around alot last season. I am putting a bushing in the pivot hole, and am going to put some large (maybe 4 or 5") washers, made of plastic or fiberglass, on each side of the pivot bolt and make the top 3 or 4 inches of the keel fit snuggly in the trunk when in the down position. Macgregor designed the keel to "lay" on the trunk when heeling, so there wouln't be too much twisting motion on the pivot bolt. Look at it like an 8 foot lever, and a heavy one at that.
You can use zip ties instead of foam every 3 ft. do not cut off the long tails.Kestle, I saw a mod that Sumner did ware he put pieces of foam a few feet apart on the wires in the mast. That stopped the noise.
Its also one of the first things I'm going to do this spring on my 26D. I might use pool noodles though.
Jeff: Go get yourself one of those 3" x 4' x 8' pink foam boards at Home Depot and cut it into long strips that are just a tad narrower than the inner dimension of your mast. Place the strips end-to-end and duct tape the ends together. Then slip it up inside your mast. The duct tape is there just in case you ever want to pull it all back out again. In addition to stopping the wire slap inside your mast, it will also provide buoyancy in your mast if you ever suffer a really hard knock down. I did this and my mast is quite now. I've also read on another list serve where someone wrapped their foam in aluminum foil first. Their claim is that it made for a better radar target. I don't have any first hand knowledge/data to support that notion but thought I'd toss it on the pile and see what happens.The wiring in the mast...that's something else.
I too had the bang - bang, whether from just being hove-to or when swapping tack's.
When I pulled the keel, I found the prob. Big hole, small bolt, sloppy fits. Remedy - I built new, wider keel with decent profile; installed st. stl. plates on inside of trunk - "J" shape, one per side. Pivot for new keel is 2" diameter 'hub' clamped between plates in trunk . Keel has 2-1/32" bore for hub and st. stl. washers on each side to minimize side to side movement. All slathered with Copperslip grease for lube. Result - noiseless free swinging and the keel can be removed in 5 mins. No need to go below under the sink and bust your head/knuckles/some of the Commandments. I do have up/down lines installed as insurance. Anyone in Great Lakes likely knows to coat everything with anti-fouling paint - darn those zebra mussels!!
