How do I remove the furling genoa?
Jwhy
Feb 11, 2013
100
Catalina 320 Kilmarnock
Blew out the very old headsail and need to replace it. How do I get it off the furler?
Jan 7, 2011
5,449
Oday 322 East Chicago, IN
Generally, you need to release the halyard tha t holds the sail up on the furler. On some furlers, you have an external halyard (you should be able to see it attached to the top of the Genoa, to the mast. Location on the mast depends on if you have a mast head rig, or a fractional rig.
On other furlers, like mine, the sail is held in place by a wire halyard in the furler. On mine, I have a metal "slug" that is attached to one end of the wire halyard, and as I raise the sail, I pull down the slug. Once the sail is in place, the slug is "pinned" in place with a cotter pin. The slug is pinned a foot or so from the bottom of the furler.
Knowing what sort of furler you have would help immensely. But these the options should give you some good clues where to start.
Greg
Likes: justsomeguy
Jan 7, 2011
5,449
I can't find anything on that unit.
Do you know if you raise the sail with an external halyard?
Greg
We have to assume a few things. You know the halyard that controls the Genoa. You have enough of the sail left to pull it down. You know how to release (unwind) the furled sail.
If you can do these things your 75% there.
Collect the sheets onto to fore deck. Unwind the furled sail on a day when no wind is blowing. Release the Genoa halyard. Move to the furler and pull the sail sail down to the deck collecting the sail at your feet as you go. Be sure the halyard is not tangled. Might want to have a helper control the line and let it up as you pull the sail down. Do not let the halyard wrap and get pulled up the mast. They are no fun trying to catch and fish them down.
Once the sail is down, disconnect the head and tack from the furler. You'll have to give us a photo or explain the connection if you need more help.
Joe
Jun 1, 2004
8,161
Disconnect the tack from the drum.... un cleat the halyard, pull the sail down to the deck.
Jan 18, 2016
782
Catalina 387 Dana Point
I have a North furler of around the same vintage.
Unfurl the sail, release the halyard, pull down on the sail - the boltrope should still be intact inside the furler even if most of the sail is gone.
Jwhy
Feb 11, 2013
100
Thanks for the help. Took it off today, much easier than I expected.
Congrats. Most of sailing seems more difficult than it really is.
Until it isn't...:)
