Mark Robbins
Is it possible to place a shower sump in the shallow bilge of a Legend 35.5. An Attwood shower sump will probably fit, but I don't know if it will be low enough to be below the shower drain. Where should the discharge hose run and should a check valve be used? I would also like to drain the air conditioner condensation pan into the sump and drain the icebox either into the sink drain or the sump. Any suggestions? As you can see I would like a dry (dryer) bilge.
