Hi all, we have an O'day 23 Mk II. The transom was rotted, and we've rebuilt it. It was a rough job and I want to make sure the outboard motor mount is properly reattached. We have a Garelick outboard motor mount with wedges that we're going to rebuilt/reuse, but with the wedges the transom and the motor mount aren't parallel. If we bolt perpendicular to the motor mount, then when the bolts exit inside the transom they are at an angle. Is this an issue? I've attached my "engineering diagram" to show the issue. Garelick's instructions say to drill holes perpendicular to the transom, but also to use wedges, this seems incompatible. I've found a few posts that show pictures of the motor mounts from the outside, but can't seem to find pictures from the inside. The previous owner simply used a big piece of starboard/plastic and tightened until it all crushed/compressed, but this doesn't seem like a suitable backing plate material.
