Centerline, thanks for the detailed description of concept and design. You are also correct in pointing out that the Keel will ground first. The keel on the V21 will need 5 feet of water, I was thinking this will cause me more problems than the rudder. I have not sailed this boat as of yet, still making repair and it is a bit cold right now in the Midwest. I have read in Venture literature that the V21 will self right only if the keel is locked into position. Initially I had planed to sail with the keel unlocked. In the event of a blow over I can imagine that the keel could come up and possible turtle the boat. I am not a excessively worrysome person but I do want to know what the potential problems are so I can act prudently.
when I had my 21, I pushed it hard in winds that i shouldnt of been out in, and in ways that should have broke something....
there was a method to my actions and I didnt care if the boat sank or if it broke. i wasnt trying to preserve anything, but I was trying to gain knowledge of how a sailboat worked in the wind and why it rounded up, and does it really float on its side without sinking, and how far over can you sail it, heeled on its side and maintain steerage and headway....
I am a lifetime powerboat owner and always pushed them towards the upper limits on the ocean and elsewhere. I have worked on fishing boats and crab boats and sometimes just going out on the sea and running the boat gently, is pushing it towards the limits of what it should do....
so my interest in sailboats came at a time when i had very little cares about anything, but had time on my hands (divorce).... and if the boat sank it was no big deal cuz I know people who could help me retrieve it, or i could just buy another one... it didnt matter how it went down, but I was learning sailing the same way I learned everything else, by going there and doing that. by finding out what doesnt work and what does.(my dad never gave me instructions, he just gave me the ax and told me to get it done)
I refined the knowledge i gained by reading books and asking questions here on this site (a sincere thank you to everyone)... and, although others may do better with a refined and organized sailing class, i dont and will never regret the fun, excitement, dangers, or experiences I went thru, doing it as I did....
so I feel I am qualified to tell you about the macgregor 21....
i can pretty safely say this with a 99% accuracy... the keel being locked down or not, will never be an issue on a lake where the waves never get over 2ft .... or the winds never get over 15mph.. but, as a mariner, (laker, river pig, or whatever term you want to use) you have to figure in the "what if" factor... because that is what will save your butt, if you take steps to prevent the "what if" event...
if the boat is tuned right, it will round up before being knocked down, although it can broach with a good tail wind.... a knock down is where the wind overpowers the boat and lays it far enough over so the wind spills over the sail, the boat usually turns, (as now the sail is more like a big fan blade) and as soon as the wind looses all of its grip on the sail, the keel will allow the boat to return to a standing position with its sail tailed out and flapping...
the boat WILL ONLY RIGHT ITSELF IF THE KEEL IS FULLY EXTENDED.... if the keel should retract, you better expect it to go turtle.... cuz it will.
with the keel extended, you can expect it to pop back up even in a broach where the cockpit scoops itself full of water...
only the lockdown bolt can insure the keel will remain extended.
a broach is a knockdown by wind or waves when sailing downwind. (a following sea) these are more dangerous. your bow can be pushed under a wave so you take one over the bow, a wave can lift the back of the boat at the same time making matters worse... it can escalate from there as the boat gets heavier with all the water it has swallowed in the open hatchway.....
broaches just arent as much fun, in my experience, so avoid them if you can, but be prepared just in case....
in normal sailing, as the boat heels, and the friction of the keel hanging sideways in the trunk will keep it extended below its pivot point, but when you broach, the boat is usually pushed past the horizontal plane, which exposes the weight of the keel to forces above its pivot point, and it is going to come slamming closed like a jackknife.
this action can cause damage itself, and if the boat gets miraculously pushed back onto its feet by a wave, the keel is going to slam open in the same manner that it closed in...
so no matter what I or others say, or how we say it, its a matter of simple physics and you will draw you own conclusions.
running aground with a swing keeler, is not an issue, or even an aggravation, its just a small inconvenience. but if you had a fixed keel its a completely different and more serious matter, but still not ALWAYS an emergency on a lake bottom... (a rocky outcrop is bad all the time)
breaking a rudder on a stump on the lake bottom while swinging on the hook is an aggravation that can be avoided if you have a folding rudder. (the keel may not ground, but the rudder can still catch a stump)...
but dont over think it or worry about it... as long as you are aware of the things to watch out for you will be fine.. its almost always those who dont know, dont care, or have their minds elsewhere that experience problems such as we are talking about here.
