How do I Install Oarlocks?
E
Eric Grannis
I have been advised to install oarlocks on my O'Day Javelin as an alternative to using a motor. Any suggestions on how to do this? I would guess that I should attach small blocks of wood to the sides of the boat in which to put the oarlocks. Any advice would be appreciated.
Don Evans
Reinforce the Area First
Glass in a piece of hardwood, such as oak in the spot where your locks will go. Once its setup drill out the oar lock tubes, and install the bronze tubes. Take a look at a custom row boat to give you ideas where it should be located and the shape of the oar lock wood blocks for aesthetic purposes. Good luck. Don
