James -when sailing vessels must give way to power
Thanks for replying. I can see you are quite knowledgeable in the Collision Regulations. However, I will take your reply as an opportunity to help educate sailors (the sailors who use wind that is - power boaters are also called sailors). There are unfortunately a few sailors around who think they always have the right of way unless the other guy is a lot bigger.....First in reply to your question, I have taught for the Canadian Power and Sail Squadron for 17 years plus 4 years for the Vienna International Sailing Club when I was working in Europe. The Canadian Power and Sail Squadron is modelled after the US Power Squadron with the first Canadian Squadron formed in 1938 so James, we volunteer our services to sister organizations.All of this teaching has among other things included the International Regulations for Preventing Collisions at Sea (Collision Regs). My knowledge has grown as I encourage discussion on interpretation under various circumstances and questions the students raise based on their experiences.James I expect my experience is less than yours, however I have a Catalina 36 and previously had a 32' cutter rigged sail boat. I started as a sailor (the stinkpotter type) in a runabout I built in high school, a sailing dinghy etc. I have sailed internationally as well in areas including the US, BVI, Croatia, Slovenia, the Greek Islands, Australia (although I wasn't in command) and various areas in Canada with the majority of my experience in the Great Lakes.That said - you provided a good list of occassions when sail must give way - I am going to expand on these a bit.I will group my responses under the applicable International Rules (which form the core of the USCG Navigation Rules).Rule 18 - Responsibilities between Vessels states part (b) states in "A sailing vessel underway shall keepout of the way of:i) a vessel not undercommandii) a vessel restricted in her ability to manoevreiii) a vessel engaged in fishing"*Rule 3 part g) defines a "vessel that is restricted in her ability to manoevre". James has mentioned some them - but it amounts to a vessel "which from the nature of her work is restricted in their ability manoevre as required by these Rules and is therfore unable to keep out of the way of another vessel. eg. laying cables or pipe, transferring provisions or cargo, a towing operation that severely restricts the manoeverability of the towing vessel, clearing mines..... I don't think I want to be nearby anyway.... etc" James, most of your examples come under these headings with the exception of the military and state/local authorities (which are not international and I don't believe they are part of US inland rules either.( I believe these are probably covered by other US laws so I won't comment on them but others should comment if they know). Canada and many other countries have their own modifications as well, however I have never heard of any that contradict the International Regulations - not that I consider myself at all expert - mostly national regulations provide additional specific guidance in intrepretation of an International Rule or they may provide additional guidance if the international Rules do not provide guidance.Back to the RulesRule 18 above applies ""Except where Rules 9, 10 and 13 otherwise require:" I will explain each of these.Rule 9 applies in Narrow Channels among other applicable facts states in part b) "A vessel of less than 20 metres in length or a sailing vessel shall not impede the passage of a vessel which can safely navigate only within a narrow channel or fairway."Rule 10 "Traffic Seperation Schemes - International" states in part j) "A vessel of less than 20 metres in length or a sailing vessel shalln ot impede the safe passage of a power-driven vessel following a traffic lane." These traffic seperation schemes are marked on charts and normally small vessels are supposed to stay out of them or if necessary to cross - cross them at right angles. Rule 13 "Overtaking - International" states in part a) "Notwithstanding anything contained in the Rules of Part B (vessels in sight of one another), Sections I and II, any vessel overtaking any other vessel shall keep out of the way of the vessel being overtaken." As I stated earlier in this thread if a sailing vessel under sail is overtaking a PWC (or any other vessel) the vessel being overtaken is stand on and the sailing vessel (or any vessel) overtaking is give way (keep clear).Regarding crossing situations - there are a number of rules that come into play. Rule 7 helps to guide people on ways of determining if a Collision risk exists. A part that gives guidance in your circumstance is part d) i) In determinining if risk of collision exists the following considerations shall be among those taken into accout:i) such risk shall be deemed to exist if the compass bearing of an pproaching vessel does not appreciably change,(ii) such risk may sometimes exist even when an appreciable bearing change is evident, particularly when approaching a very large vessel of a tow or when approachiing a vessel at close range." (James this was a point you made earlier in the thread) In addition, Rule 8 "Action to avoid Collisions" states in part a) "Any action taken to avoid collision shall, if the circumstances of the case admit, be positive, made in ample time and with due regard to the observance of good seamanship.b) Any alteration of course and/or speed to avoid collision shall, if the circumstances of the case admit, be large enough to be readily apparent to another vessel observing visually or by radar; a succession of small alterations of course and/or speed should be avoided."There are other rules that apply in interpretation of the rules however I will quote a part of one that I always emphasizeRule 8 f) i) " A vessel which, by any of these rules, is required not to impede the passage or safe passage of another vessel shall, when required by the circumstances of the case, take early action to allow sufficient sea room for the safe passage of the other vessel." It is very important to let the other vessel know that you know the rules and are going to take action to allow them to stand on.... otherwise they may do something unexpected to avoid you if they suddenly at the last minute realize you don't know the rules (happens too frequently). Rule 16 also applies and says essentially the same thing.Regarding which way to turn if you must give way in a crossing situation - it is a question of seamanship in assessing what exactly the situation is - other vessels approaching, channel width, hazards, reduced visibility and detection by radar alone, how close to an actual collision you are etc. so that there is no clear rule except use good seamanship - however when you can see the other vessel in a crossing situation (if there are no other conflicting constraints) Rule 15 states "when two power-driven vessels are crossing so as to involve risk of collision, the vessel which has the other on her starboard side shall keep out of the way and shall, if the circumstances of the case admit, avoid crossing ahead of the other vessel. ie. slow right down so that you will not cross ahead or make a clear alteration of course to the starboard to pass behind the stand on vessel. You could also turn to port and parallel the crossing vessel (substantially short of the crossing vessels course.)*Finally, lest someone read this reply and not my earlier comments - a vessel engaged in fishing has the right of way only if they are substantially restricted in manoeverability. It does include a "a vessel fishing with nets (as you indicated James) lines, trawls or other fishing apparatus which restrict manoeuverability, but does not inlcude a vessel fishing with trolling lines or other fishing apparatus whhich do not restrict manoevrability" ie. a sports fisherman with trolling lines or downriggers can make an abrubt turn if need be. However be reasonable - go around them if you can - they are not moving faster than you.I think it is time to get off the soap box - but with a caution - I have only quoted parts of the rules that specifically respond to the e-mail from James - I quoted the parts which in my experience are most applicable to specific comments that James made about sailboat right of way and other comments he made. I would encourage those that are reading this to take a boating course from a well recognized organization like USPS or CPS or any of the organizations that James mentioned. These organizations offer a wide range of courses that cover a wide range of information that is important to sailors . You can learn the rules from the book - however it can be sleep inducing. It is better to learn the rules with lots of examples and answers to questions that people have. It sticks better.I think I got carried away.... hope this was useful to some readers. If you got this far...
