The slot effect - windage =
Hi Joanna, My small, 25ft Hunter, didn't go to weather that well either but 65 degrees is pretty bad.1) you need not be reefed in 10knots of wind.2) when reefed it is tough to get a good sail shape from the main, unless it furls into the mast etc. you really need to get into your reef points, make an 'earring' and use a cunningham or something to get a good shape.3) Work n good 'slot effect' using the jib to accelerate wind across the luff of the main. Yarn colored tell-tales are good for this prupose. Youreally need to play with it for good results.4) The Hunter is a roomy little sloop, at least mine was, with a fairly high cabin top for that size vessle and there are sacrifices...*soap.5) Weight, windage, current, swell and lotta many variables to your area and boat, is your bottom clean, any extra drag doen there? Gotta put on a mask & look. Pull your outboard up, a lotta little things, but a full main and 100% jib should give 50 degrees...;-)
