I've used Petit Aqua Clean
Several years ago when I could get it, I used Petit Aqua Clean (a water Base ablative) for several seasons on my C-22 that I leave in Long Island Sound during the season.As far as keeping barnacles etc. off, it was fine as it has a high copper content. It does not have an anti-slime additive so natch there was slime.The advantage is you need only water for clean up which could be important for people who have trouble using paint thinner.As I now use oil base ablative, I think the water base Aqua Clean was a bit softer and hence slower than the oil base.Further, I annually sand and paint my bottom. The water based paint really kicked up a lot of dust when sanded, but it is a little easier to remove.As for an inflatable, I do not know if all water-based ablatives can be used on them.I suppose you could try using the water base paint to see if the clean up part is an advatage to you.
