Hour meter 323
34
Beneteau Clipper 323 St Peter Port
The hour meter has stopped working. Yanmar 3ym20, is this common and does anybody know a simple fix?
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
First, check all of the wiring connections, and the wire for continuity. look for things that may have vibrated loose, or breaks in the wires at the connectors. Not uncommon.
Beneteau 343 Saint Helens, Oregon OR
Mine came back when the weather improved. I installed a cheap one in the top of the housing inside the lzarette on my 343. Easier to see also. There is slight variation between the two.
Dec 23, 2006
23
Beneteau 323 Absecon NJ
I have the same problem. When I researched the hour meter in the RPM gauge I was told that the hour meter works thru a different method of pick up now.
It only worked 2 years . My boat is a 2007. I'm using an aftermarket hour meter powered by the engine compartment fan circuit.
Jun 21, 2004
2,901
Beneteau 343 Slidell, LA
I recently had the same problem on my '06 Ben 343. The tach worked fine; however, the digital hour meter failed. I read somewhere that you could purchase a new VDO tach/digital hour meter from Torrenson or Mack Boring Yanmar for approximately $225. I opted to purchase an analog meter from Ebay for approximately $40 and installed it on the black plastic housing that covers the entire instrument panel asspembly. Works well and is actually easier to read.
Mar 3, 2009
30
Beneteau 49 Atlantic City, NJ
I have a 2008 ben49 with a Yanmar with the LCD hour meter. Last year the LCD would get dim and fade away to where the numbers would not be visible. They would eventually come back but intermittently fade out. I know the owner of a cat with twin Yanmars and both LCD hour Meters are doing the same. It must be a Yanmar defect.
May 20, 2011
34
Have you managed to resolve it?
Nov 24, 2012
586
Must be one source for LCD displays that all engine manufacturers use. In our harbor virtually all of the displays have gone into fade mode - doesn't matter what engine manufacturer.
I was lucky in that the display came on before haulout. I bought an analog display connected it to a power cord (12v) stuck it in my car and ran it until it duplicated the LCD display for engine hours.
Mar 3, 2009
30
I have not resolved the problem. It started late in the season so I did not do any troubleshooting. Now the weather has finally broke I will check the wiring, but I doubt that's the problem. I'll purchase a standalone hour meter and mount in by the nav station. It'll be more convenient at the nav station anyway.
