Head Sail - Thanks for the (original) post and it makes for a good reminder to check those connections. While I can’t answer your question I’ll volunteer a little editorial comment.
For some of us it seems there’s never enough time in a day so we tend to do those things higher up on the squeaky-wheel list. “If it ain’t broke don’t fix it” so looking for potential trouble items tends to be at the bottom of anyone’s list.
Checking electrical connections is probably not the highest item on anyone’s list; however, a 30 Amp AC circuit carries a lot of power and some of the DC circuits also carry a lot of power. Four golf carts wired for 50 Amp DC with 00 cables can put out a lot of power too.
The problem with our boats that run using a diesel engine is the engine really vibrates. Even with good motor mounts there is still vibration that is transmitted to everything throughout the boat - including the electrical conductors. This constant vibration causes a certain amount of vibration in conductors and in the case where they terminate at, say, a screw, this can eventually cause the screw to loosen or at least the pressure of the screw on the terminal to loosen.
One place where a loose contact happens a lot is at the boat’s shore power connection. The early result here is usually a sign that the shore power cable end shows some sign of melting and it it’s not caught early it gets pretty ugly.
Over the years I’m had various wire terminal screw connections become loose (mostly in the main panel) resulting in some device not working or only functioning with a problem. One major malfunction was while running though pea soup fog in an area with lots of rocks (north side of Prince of Whales Island) and both the autopilot and the radar started having weird problems. The culprit was a loose jumper cable connection from the main breaker bank (with the incoming cable from the battery) to the second breaker bank (with the radar and the autopilot). The fix was something like a 1/4 turn on the screw. Lesson learned: Check those cable and wire connections to make sure the screws are tight.
Phil: the original title seems to have disappeared.
