Hot Water
aw6686
Jun 12, 2014
14
Hunter 33.5 Ned Dimes Marina
2011 Hunter 33.5. The hot water pressure is low and the temperature only gets warm both with water heater on or engine running. Also, water pump runs every 4 minutes even when not using water. Any suggestions? Thanks
Gene S
Nov 29, 2015
181
Delphia 37 Tacoma
Is yours electric and engine heated? I had a collapsed engine coolant tube from the engine. Do you have a temp limiter valve on it? The running every 4 min might be a leaking accumulator. There has to be a check valve there or in the pump to maintain pressure. Just my guesses.
aw6686
Jun 12, 2014
14
I ran the engine for 2 hours and got warm water.
I turned on the water heater on shore power for 2 hours and got warm water.
I turned the temp valve all the way up and got warm water.
I will check the accumulator for leaks.
Thanks much!
Nov 6, 2006
10,256
Pump running every 4 minutes is either a leaking valve in the pump (small piece of debris?) or more likely, a fitting in the boat somewhere is leaking. I think all the connectors and fittings are in places where you can put your hands on 'em.. so trace the lines and touch the underside to feel for leakage. The low pressure may be deposits in the faucet fixtures or debris in the little aerator screens at the faucet outlets.. Water not hot could be a mixer valve stuck.. I don't think the (scald preventing) mixer valve was standard on the boat, but someone may have put one in..
Some installations had the water heater hose connections on the engine in the wrong place.. If you have a picture of the heater connections on the engine, it would be helpful. If it acts the same with electric power, and all the air is out of the tank, then mixing valve or something else.
aw6686
Jun 12, 2014
14
Will check the valve in the pump, connectors and fittings for leaks.
If the faucet aerator screens are dirty wouldn't the cold water pressure be low as well?
Thanks!
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
If you have a mixing valve to limit the temperature of the hot water remove the valve and check the screen at the connection between the mixing valve and the hot water input. If the screen is blocked or partially blocked you will get more cold at a reduced pressure. Net result, Low pressure & warm not hot water.
Good luck.
Jun 23, 2016
2
Hunter 306 Monroe, Mi
The filter on the intake side of the water pump can get clogged and limit the pressure. Have to clean it many times during the season especially when getting things ready in the spring. Also you probably have a leak somewhere in your water lines. Probably at one of the fittings. I've had this problem and found the fitting in question and it was just a matter of reseating the quick connect. It was leaking into my bilge pump which caused it to run more often as well. I assume you mean your water pump is running often, not your bilge?
aw6686
Jun 12, 2014
14
That is correct. It is the water pump not the bilge.
I would think the bilge pump would be running and the water level would be dropping but that does not seem to be the case.
Thanks much for your input and I will check the connections:)
Nov 6, 2006
10,256
Without an accumulator, not standard on the boat, it only takes about a tablespoon of water leaking to make the pump start.. Not saying that is what it is, but that is the most common cause of the pump "short cycling". Some tablespoons of water in the bilge is tough to notice.
Likes: aw6686
Gene S
Nov 29, 2015
181
Delphia 37 Tacoma
I forgot to ask, when you turn on the hot then cold at the faucet, is the flow rate the same for both? Just trying to get clues to the problem. If you have a relief valve on the tank, maybe you can let some out to see the temp if you're careful.
aw6686
Jun 12, 2014
14
The flow is not the same much less for hot water. I will check for relief valve with caution.
Thanks!
aw6686
Jun 12, 2014
14
Great new! The water temp has corrected itself.
Found loose water hoses at the outside shower. Tightened both and water pump turns on only when being used.
The mixer(white fixture where hot on cold mix) on the other side of the water hoses leaks like crazy when using the outside shower. Any suggestions on how to replace that would be great. The access is through the aft cabin a bit of a tight spot.
Thanks for all you help!
Jun 11, 2011
1,243
Hunter 41 Lewes
Glad you found the leak. The anti scald valve on the water heater actually has two screens in it. They are in the form a a washer and sceen at the union fittings, at least on my boat. You will find the one coming from the water tank clogged. Easy clean and reinstall, ten minute job depending on access. Hot water flow will again equal cold.
aw6686
Jun 12, 2014
14
Thanks uncledom! I will check those screens.
Any ideas regarding the outside shower? When using the shower it leaks like crazy in the aft cabin behind the aft compartment door where the water hoses connect to the white mixer.
Thanks much!
Jun 3, 2010
177
Hunter 27-3 Erie
Ours was also trashed by the PO's mechanic and needed to be replaced. I got the make and model off the unit and did a Google search last August. I found a place in Florida that sold the OEM shower units for less than $75. I was looking through my records here, but that information is at home. As I recall it is the same unit used for transom showers on many power boats as well. The trick is to get the OEM unit so you don't have to mess with the hole it fits in.
As far as that anti-scald valve uncledom referred to, we had one and the screens clogged after about 30 seconds. I spent a huge amount of time and effort trying to clear the system. What I ended up doing is removing that valve and replacing it with new fittings, no screens and now have no issues. Every boat we have had was plumbed the same way and worked fine. I figured that if I manage not to scald myself at home every day I should be able to do the same on the boat? IMO the anti scald valve is not needed and was a huge irritation to me because of the clogged screens. BTW, I understand the screens will clog if you use the fizzy tablets to keep your fresh water fresh?
Jun 11, 2011
1,243
Hunter 41 Lewes
Sorry I don't know who made the shower assembly so I can't point you in a direction.
Jun 2, 2011
347
I pulled the complete assembly forward when I replaced mine. Cleaned the caulking, resealed and reinstalled the original assembly. It was a lot easier than trying to access from the bottom. If you do this you have to cut the existing caulking with a reasonably sharp scraper.
Likes: aw6686
aw6686
Jun 12, 2014
14
Removed the outdoor shower, tightened the cold and hot hoses after replacing the parts of the mixer. Had to really tighten it to stop all leaks but was able to with our breaking the parts. Re-installed and ready to go!
Thanks all for your help!
AW6686
