Hi Everyone,
Saturday afternoon we noticed that when we turned our faucet on and selected the hotwater, no water comes out of the faucet. Only when the cold water is selected. So I crawled back to the hot water tank (Seaward F1200, 11 gallon) and pulled the red and blue hoses off. Water poured out of both holes of the water tank. I had my wife turn on the water pump and water poured out of the blue hose. I then connected the blue hose to the water tank, left the red hose off, and again turned on the water pressure, pump stopped running as if pressurized. No water pressure out of the tank. Pull the blue hose off and water sprays out of the hose but it seems like water can't enter the tank, only flow out of the tank.
Two questions:
Is there a valve inside the water tank that is maybe broken?
How do you get the hose barb off of the tank on the cold/blue side? It spins around , so it is not screwed on, and it seems to have a sleeve that slides up and down.
Two questions:
