What am I doing wrong?
Last fall when I winterized my drinking water system, which uses Whale lines and fittings, I disconnected the 2 brass fittings on each end of the hot water tank, where they enter the boats cold and hot water lines. I then ran a short length of whale tubing between the female connectors on the cold (blue) and hot (red) water lines. This allowed me to flush the system with antifreeze – bypassing the hot water thank. Everything worked well and I flushed the water system and drained the hot water thank.
Today, I reconnected the 2 brass stem adaptors (one has a check valve on the cold water input line to the hot water heater) to their respective cold and hot water lines. Now I only have cold water coming out of the tapes. No hot water comes out of the hot water tapes.
See attached schematic of my water system (mine has no accumulator tank).
I thought that the check valve on the cold water line was not connected correctly or was not working properly, so I removed the check valve and checked its installation. I also blew on the valve and it let air through but didn’t when I sucked on it. So it seems to be working.
The only thing that I did was to change the rubber washer in the brass stem fitting with the check valve where it mates with the steel covered line leading to the hot water tank. The original washer was totally crushed and some of it was missing.
I also confirmed that there was no blockage in the hot water tank (when air pressure is applied to the cold water input line water is freely expelled out the hot water output line).
Does anyone have any thoughts on what I’m missing?
Gary
C309 - Glory Days
Gary
C309 - Glory Days
