Water Heater ProblemsThe Hot water system on my Bavaria 32 consists of a cylinder located under the aft bunk. There are various hoses coming and going from it. Two of these hoses are black and come from the engine to supply heated water for the system which operates on a heat exchanger principle. These hoses enter / exit the cylinder by way of bronze screw on fittings with barb type tails. One of these fittings has cracked and is leaking engine coolant. I am unable to locate a replacement brass fitting here in Sydney. I can’t even find out the name of the manufacturer of the tank.Has anyone got any suggestions? Please don’t tell me to go to the Bavaria Dealer because they don’t want to know you unless you are buying a new boat.Thank you in anticipation and Happy New YearPeter TierneySydneyAustralia
