Scott
I have a 1988 Cat 27 with the typical 6 gal. 110v and engine heated round hot water heater and can not get rid of a smell in the hot water. The cold water side is fine. I would describe the smell of the water as a "burnt electric or plastic" smell. The 110v, 1250w element was replaced this year and the therostat set on about 110 degrees. I did not have this problem in years past and the wife is getting upset...I tried to bleach the tank and lines but that did not work.Any others with this problem or can recommend a fix?
