Hot water relief valve
Apr 10, 2010
122
Catalina 310 166 Dartmouth, Nova Scotia
My pressure relief valve on my hot water tank is 150 psi. The domestic water pump is max 40 psi. I am considering replacing it with a 40 or 50 psi relief valve as the 150 psi will never be reached as it will blow every hose onboard. Before I change it I would appreciate the considerable experience and expertise of collective forum. So over to you. Thanks.
The pressure relief valve needs to be high enough to avoid nuisance blows. Setting it too low, at 40 or 50 psi will cause it to blow every time the HW tank gets hot.
When water heats up, the pressure increases, the pressure relief valve is there to dump the pressure before the tank blows up. Trident potable water hose has a burst strength of 250 psi which is well below the 150 psi of the T&P valve.
So, there is no need to replace the valve. At least once a year excercise the valve by lifting the lever a couple of times to make sure it releases.
Jan 4, 2006
7,466
An additional item to Dave's dissertation above is to install an expansion tank. This will avoid overpressuring the system each time you start your engine with a cold hot water tank. This usually causes your relief valve to weep on startup.
Aug 21, 2017
54
Sunfish Thistle NY
I think this comment is backwards. The burst strength of the potable water hose mentioned is 250psi and is well ABOVE the 150 psi of the pressure relief valve dump point.
Jan 4, 2006
7,466
Oh yes, very true, very true indeed but we try not to mention these minor little things in polite sailing society.
But Jeez, talk about getting it backwards. Holy Crap, I think Dave was smoking the drapes when he said :
Everyone and his pet dog knows that when water heats up, it's the volume that increases. But if that original volume is constrained, then and only then does the pressure increase.
BTW, don't mention this to Dave. I hear he upsets easily.
Likes: JamesG161
First you accuse me of writing a dissertation, then you tell me the explanation isn't long enough. Will you make up your mind.
Apr 10, 2010
122
Gentlemen, thank you for your colourful and interesting responses as well as your repartee with respect to one another. I will therefore leave the system as it is and contemplate where a possible expansion tank will be placed physically. Again thanks to you both and others who had read this thread and gave it some thought.
Likes: kloudie1
colemj
Jul 13, 2004
850
The expansion tank goes in the cold inlet line as close to the water heater as possible. There should also be a check valve between the cold water circuit and the expansion tank to prevent the pressure from migrating backward into the system.
Mark
  • Helpful
Likes: JamesG161
JamesG161
Feb 14, 2014
7,961
Hunter 430 Waveland, MS
Tips on CHECK VALVES:
1) Flapper type or Ball type [in line orientation important]
2) Double Clamp connections.
3) Function tested each season.
______
The Water Heater "Relief Valve" is a Check Valve :cool:
________
Visual of a Big FLAPPER type.
______
In the chemical industry we had a saying.
Like Murphy's 1st Law.....
Check Valves DON'T :facepalm:
Jim...
colemj
Jul 13, 2004
850
Jim...
While the relief valve is a check valve, it is not in the proper place for that function, and cannot serve that function.
The worst that can happen with a check valve on the cold water inlet is that the cold water circuit gets hot water flowing back into it. Which would be the case if there wasn't a check valve. Pretty much all water heater manufacturers prescribe a check valve on the cold water inlet.
Mark
Clydo
May 28, 2013
367
Catalina C310 SF Bay/Delta
As long as we are talking about water heaters mine is set at uncomfortable high
temp. Haven't stuck my head upside down in that compartment but before I do how do
I reduce temperature? Thanks a bunch.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Any water heater heated by the engine coolant will get up to engine operating temperatures- much hotter than a normal household heater. The usual solution is a mixing valve on the heater outlet that mixes cold water with the output to balance the temperature.
Clyde
Clyde,
When using electricity, turn it off after about a half an hour. Don't leave it on all the time. There is no temperature control.
When using engine heat, David's right, no control.
David's solution with a mixing valve would work, but I just use those other handy mixing vales: the faucets.
