[FONT=Verdana, Arial, Helvetica, sans-serif]Here's a question for the group. I have already posed this question to both Jim the product manager of Shields hose and to Trident hose and neither have a solution other than to suggest a an FDA approved PEX tube.
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]#1 Find me a small marine engine that runs at a nominal operating temperature lower than 145-150 degrees?
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]#2 Now find me an FDA approved potable water hose [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]that has a max working temp above 150 degrees that is [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]made of nylon reinforced PVC. this is the type installed on most production boats for potable water.
#3 Find me even a hand full of production boat builders who offer, as standard equipment, a way to control the temp of the water heater when it is running off the engine?
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Here's the rub..[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]The water heaters in boats will eventually heat to the engine's running temperature if run long enough. There is no means, on any production sail boat water heater I have ever seen, to temper the water temperature as it reaches a pre-determined max set temp other than when it is running off 120 volts. I have seen mixing valves used but not very often and usually only on high end/ high dollar vessels.
With a residential indirect fired water heater the aquastat is set at your desired temperature and the aquastat subsequently turns on or off either a zone valve or a circulator to direct boiler water to the indirect fired water heaters coil. When the water reaches the max set point the aquastat breaks and stops the circulator or zone valve from over heating the water in the heater. Most marine water heaters, at least in production boats, are not plumbed this way and when the engine runs the coolant flows until the water heater is the same temp as the engine unless you add a mixing valve..
On our boat the engine runs at 180 degrees. Most PVC FDA rated water system hose has a max temp rating or between 140 & 150 degrees yet the builders have failed to catch on to this dangerous mismatch or address high & potentially dangerous temps in water heaters and the low temp ratings of the hose builders are connecting to it.
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Numerous builders still use 150 degree rated hose on 180 degree potential systems???
How safe is this? How safe is 150 degree + hot water for that matter? Not very according to Jim the product manager at Shields Hose who I ran the scenario by. Not only will max working pressure be reduced as temps rise but the hose gets so soft that it can rupture. 180 degrees is enough to scald and burn...[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Am I off on my thinking here that this is a potentially unsafe mismatch?? I am in the process of converting our current boat to PEX tubing after having a hot water supply hose blow right off the water heater on our last boat and discovering this temp mismatch.
Perhaps Peggy can offer her insight..
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Just thinking out loud...
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
