Hot Water on an 80 H-27
Joe
I would like to add hot water to my 80-H27. Since the 2gm is raw water cooled,I can't install the typical heater. I do have propane intstalled for the stove. Can you let me know if and where I can purchace a small on demand propane water heated? Thank you.
A
Alan Nye
Will be interested
Will be interested if you get any recommendations, I always look for limited use of the propane and the need to know exactly when I turn it on and when the appliances are lit. However, someone may have better experiences thatn I. Good luck
mike from westwind
travel traler hot water
the units for a tent camper or a travel trailer are very reasonable the problem is the exhaust pipe...the only place you can mount it without a through hull is high in the cockpit under the starboard seat...the exhaust runs into the cockpit (small 2 inch hole)and it really doesn't have to run all that long to get the job done so there is the trade off.
