Hot Water on 2009 Beneteau 31
Apr 26, 2019
10
Beneteau Oceanis 31 Toronto Islands
I have not been able to get hot water on our 2009 Beneteau. Neither electric or engine. Owners manual has zero info on the water system. Any suggestions, is there any kind of reference anyone knows of? Thanks, T
Mar 20, 2016
595
Beneteau 351 WYC Whitby
Are you sure the tank has water in it . Maybe it was bypassed to winterize it.
A winterization bypass would be my guess too. I don’t think Beneteau had those from the factory, but a previous owner may have added one and left it in the winterization mode. Trace the plumbing and see if you can find it. There should be a thermostatic mixing valve but then you’ll probably also find the bypass.
Apr 26, 2019
10
[/QUOTE} Thanks - I am beginning to wonder whether there is water in the hot water tank as well. The first time I turned on the electric water heater all electrics on the boat shut down. Took a while to find the (undocumented) blown breaker under the starboard cabin bench. Then I discovered a reset switch under a plastic panel on the h/w tank and re set that. But still no hot water. I can feel hot water going from the engine to the h/w tank, but no impact on water temp. So, maybe prob is no water in the tank. I am inexperienced with boat plumbing, was hoping there was some kind of reference material avail. Will keep plugging away.
Apr 26, 2019
10
Hi... thanks. Embarassed to say had not considered the obvious. Will go over system again. Find the plumbing system a bit confusing.
Turning on the electric element if the tank is empty could have damaged the element. The damage is more likely to burn out the element than short it though, so I’m surprised that the circuit breaker blew. If you feel heated coolant going to it from the engine that’s a good sign. Keep checking around the heater for the bypass and hopefully you can at least figure out how to get hot water when the engine is run. After that you can troubleshoot the electrical side more.
Mar 20, 2016
595
It's usually a hose connecting the hot and cold together bypassing the tank .Uncouple and one goes to cold input blue or blue striped hose and the other red or red striped goes to output hot water.
Take a picture of front of tank and hoses and post
Apr 26, 2019
10
Thanks, will do. I've done a little digging on West Marine, other internet resources re freshwater systems. Now that I have seen several diagrams its making a bit more sense. I will tackle it again and post a few photos for any input forum can provide.
Apr 26, 2019
10
Not so hard:
Thanks have had a look; good basic explanation; also found reference on BoatUS. Will be back at boat tomorrow looking for possible bypass valve.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Please note, there may not be but a single "by pass valve." There are many ways to bypass the water heater for winterization purposes. Bypass kits usually include two valves. I just disconnect the water heater and install a specially made bypass hose to take its place. So, look closely, maybe even make a diagram, before jumping in.
Likes: Stu Jackson
Jan 7, 2011
5,878
Oday 322 East Chicago, IN
My bypass set up uses 3 valves.
First launch of the boat, I got 2 of the 3…missed one.
Replaced hi-temp reset, checked electric elements, still no hot water :confused:
Then I found the 3rd valve….and boom, instant hot water!
Greg
Likes: jviss
Jul 23, 2009
919
I have a 2008 B 31. It has no factory bypass valve. It does have a mixing valve.
How long are you allowing the engine to run to heat the water? in the slip or underway? My water will get hot enough in 30 - 45 minuets of cruising.
Tip - make sure the transom shower is turned off, not just at the spray head.
