Steve Stringer
I just purchased this 82-H30 and need to replace the 6 GAL hot water heater (HWH). In the plans the HWH is shown in the starboard locker. Mine is centered under the cockpit. There seems to be no clearance to remove it without damage to the fiberglass unless I remove the engine. Can someone tell me how/where to remove this HWH? I neeed a replacement HWH with fresh water heat exchanger. Any recommendations?H30 OWNERS: Is your HWH centered under the cockpit right in front of the fuel tank?Thanks,Steve
