I am changing over my sea strainer from the plastic OEM to a bronze Perko. Catalina uses Marelon thru hulls. They used barbed fittings that are probably nylon and very thin walled. Using two hose clamps has really deformed them. I decided to buy Groco bronze barbed fittings for this upgrade. I'm not happy with the way these fittings are made. It appears for economy purposes Groco has casted duel barbs for use with either 1/2" or 5/8" hose. If you cut the 1/2" barb off like I assume you are supposed to do there isn't enough barb length to double clamp the hose. If I leave it on the ID is too small. The ID's are casted @ 1/4" on the 1/2" barb and 3/8" for the 5/8" barb (1/8" wall). I bought 316 SST hose clamps that are 1/2" wide and the barbed length is roughly 5/8" so it is impossible to use two clamps as is recomended.
Opinions?
Opinions?
