Hood LD question.
CMM
Catalina 30mkIII Falmouth, ME ME
The top plastic pieces, top bearing assembly, on my Hood LD 810, has fallen out for the third year in a row. These two little piece plastic assembly insert into the top extrusion and keeps the forestay centered. The two pieces are held in place by two screws that enter from the top and expands the plastic as they are screwed in.
Has this happened to anyone else or does anyone know how to remedy this from happening again ?
Jul 8, 2004
155
Hunter 33.5 Portsmouth VA
I lost 1/2 of the top bearing once. It happened when I was working to convert the LD to a SL unit. I lifted the entire luff assembly and when I lowered it I heard something hit the deck and then a splash. It took a little while to figure out what had happened. Here is the final verdict: Properly installed, the top of the foil assembly should be about 1-3/4" below the swage at the top of the headstay wire. While not snug, the hole in the top bearing fits the forestay wire, but it is only slightly smaller in diameter than the swage fitting just above it. When I lifted the luff/drum assembly, the top bearing was jammed onto the swagged portion of the fitting that connected the headstay to the mast. When I pulled the luff/drum downward, the top bearing remained stuck on the swage and pulled out of the foil extrusion. The small screws and plugs holding the bearing halves into the foil weren't meant to handle this type of loading.
I purchased a new bearing assembly and installed it in the usual way and have not had any problems since. However I am very careful to monitor any luff upward movement if I am working on the furler.
IMO, it would be pretty hard for the bearing to work its way upward in normal use. I see you are from the colder region. Are you stepping the mast for winter storage? Does it happen during this process or when you re-step the mast in the spring? Could be you are experiencing the same situation I did.
Good luck with finding the cause!
Feb 2, 2006
470
Hunter Legend 35 Kingston
Similar problems, but I don't have any screws holding my bearing assembly in place. I had one half of the bearing assembly fall down and land on the deck, and was able to recover it and reuse it.
I believe that mine came out because, a day earlier, I had hauled the halyard swivel up a little to high, and it pushed the bearing out.
I taped it in place last year just to make sure it wouldn't wiggle out, but maybe it deserved something a little better this season.
Pat T
Feb 15, 2009
162
Catalina 36MKII Waukegan, IL
Same happened to me
when I had my Catalina 30. I ordered a few extra bearings from Hood. They usually stayed in a year or so. I would think a little rigging tape would help and get you an extra year maybe. I do remember also that the system continued to work fairly well w/o the bearing so it's not a show stopper.
