Common Sense
If the thing is outside, there should be no problem. C0 has to be relatively concentrated to be lethal, and there are warning signs long before that happens. As long as you have fresh air to breath, the tiny bit of C0 that you might inhale is not going to be a problem.C0's lethality comes from the fact that it will bind to the hemoglobin in your blook more readily than oxygen, taking oxygen's place in your bloodstream, and therefore denying it to your body. But there has to ba a steady supply, because you breath it out, just like CO2. One whiff takes the circulatory ride through your system, but won't kill you.All the reports of suffocation you will read about involving C0 will involve closed cabins (usually with heaters and sleeping occupants) without ventilation that let the CO concentration rise to unhealthy levels. Even heaters that give off carbon monoxide are safe to use in your cabin, if adequate ventilation is arranged.The first safety device is your nose. Since a generator is going to run on a petroleum-based fuel, the unburned hydrocarbons in the exhaust will give it an unpleasant smell, and you can use this as a guide. Any place you are not discomforted with the smell of exhaust fumes is plenty well-ventilated.The next safety device is your brain. The most predominant symptom of building CO in your blood is a driving headache, resulting from your brain not getting the oxygen it needs. Mountain climbers experience the same oxygen-deprived headaches. This is a sign to get to fresh air.CO meters are valuable, but I daresay the only time you'll hear one go off is when an exhaust leak from you engine raises the CO level in the cabin/salon/engine room (wherever it is mounted). I don't see how it would ever go off if you just had your generator humming along on the cabintop, unless there was absolutely no wind whatsoever. Putting the gen. anywhere before the mast is plenty of precaution. Put it to one side of the cabin trunk, then sitting on the opposite bench in the cockpit, and you'll never even smell it.
