Honda BF8 Impeller
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
By chance, does anyone know where the water pump is located on a Honda BF8 outboard? If it helps it is a '98. I tried googling the info but could not find anything. The manual I downloaded from Honda also does not show the location. I'd like to replace it this winter. Also, is it safe to assume a diy'er can change the impeller without much difficulty? Thanks in advance, Manny
Manny
Oct 5, 2006
983
Jun 2, 2004
3,650
If It Is The Same as the BF15
It is on the top after you drop the foot. The only tricky part is the gearshift rod. It unscrews and you must keep track of how many turns so that it goes back into the right place and will shift into reverse and forward. If you are handy at all it is definitly somthing you can do. We were unable to find a manual for the model we were working on but it was very much like all the other ones I had done and we had no problem doing it without the manual.
Jun 2, 2004
3,650
Aug 26, 2007
284
Hunter 41DS Ventura, California
Honda Impeller Replacement
Manny, If you drop the leg section above the bottom end and then separate the two you don't have to remove the threaded top cap- much easier and a lot faster.
Aug 26, 2007
284
Manny
Oct 5, 2006
983
Thank guys
Sounds like it shouldn't be to difficult. I'm going to order the part from my local Honda dealer and hopefully they'll let me take a look at an exploded diagram. That should help a little also. Manny
Manny
Oct 5, 2006
983
Thank guys
Pearson 26 Annapolis
Keep us posted...
Manny, Please let us know how the install went. I also have a BF8, which I need to replace the impeller on. Thanks! David
Keep us posted...
