Honda 10 hp powerhead in Honda 8 hp frame ignition problem
Jun 11, 2018
2
Clipper Marine 26 Port Hadlock, Wa
I "rescued" an 8 hp Honda outboard, pre 97. It had been submerged in salt water and left laying on the beach for who knows how long. I got it started and it overheated instantly. I turned it off immediately and tore into it. Discovered that salt had clogged all of the cooling passages. When I attempted to disassemble the power had the nuts and bolts were so hard to remove that I ended up breaking the head. I checked out the rest of the frame and was able to get all the cooling passages clear. I bought a 10 horsepower power head. I installed it and bought all new electronics due to the fact that it was a point ignition system. The eight horsepower power head had a CDI ignition system. The only thing that was not new on the 10 horsepower was the flywheel. I checked all the wiring, all other specifications, timed it to factory specifications. It would not run. I set up a manifold to test the plugs outside of the head and I got sparks. I reinstalled the plugs into the engine and it still would not run. I removed the plugs and introduced a few drops of gasoline into the cylinders then reinstalled the plugs and it would not start. I removed the plugs sprayed starting fluid into each cylinder, reinstalled the plugs and it still would not start. I checked the magnets in the flywheel to be sure that they still had magnetic fields. They did. I then checked online to try to find out if I required a different flywheel for a point ignition system. I read across many sellers that indicated they have a flywheel for a 7,8 or 10 horsepower Honda. I noticed according to Honda, black flywheels were for the point ignition system, and red flywheels that indicated they were for the CDI ignition system. The flywheel that that was with the eight horsepower frame was black. I have checked and rechecked all the wiring, checked and rechecked all the specifications for the different parts that are on the power head. Does anybody have any information for me at all? Any good guess's? The number on the power head is B 100 -1000 -820, the Honda frame number is BACL 1000542 (mfg 1987), and is commonly known as a BF8A. I have found that the only difference between and seven and eight or 10 horsepower is the cam.
Thanks in advance for any help that anyone can get me, I am at my wit's end.
Nov 6, 2006
10,096
IF the valves are seating (valve clearance checked), then you could have a difference of spacing of the magnets in the flywheel that would be affecting the timing or the strength of the spark.. Showing a spark in atmos conditions (spark plug out) is much easier than having a spark under compression conditions (spark plug in) ..
Jun 11, 2018
2
Thanks for the reply. I ruled that out and have not checked. Compression in both cylnders equal, and when pulling the starter cord, gas escapes from the exhaust into the tank, indicating valves seating and responding. However, since I have not actually done a valve adj check, I will do that and report. Thanks for the reply.
