Bad Fiberglass Box Experience
Hi Mark - you asked if anyone else had any experience, good or bad. Well, sort of related, a few years ago, unable to locate suitable plastic boxes for golf carts to fit my battery compartment, I set out to make my own using 3/4-in plywood. I came up with a list of materials and it seemed like a cheap way to go. I made the box according to instructions in Wings book.Meanwhile, about a month later (it seemed like it was that long) I was just finishing my project when I came across some ready-made boxes at Dyno in Seattle which were exactly what I needed. Because my project box had some shortcommings, such as appearance, size, weight, I opted to buy a couple plastic ones. Figuring up the cost of my wood box, materials only was over $100, which means I had grossly under-estimated the project (and I've got a lot of construction estimating experience). Labor, my time is worth something, I'm got untold hours in it. Fiberglass doesn't stick upside down very well! Nor very well on a side wall, it likes to slither down until it kicks. Due to the several layers of glass required on all the corners, inside and outside, one must work the project in spurts. Also, it's difficult to mix up small batches of resin or epoxy and get the proportions exactly right.By the way, I still have my home made battery box as I can't bare to throw it away. Hope this helps.
