I have a crimper tool to crimp aluminum ferrals and buttons, but a real steel swage fitting takes like 30,000 lbs of force. The force is so great on those machines the guy put a rag in there flat and pressed it and that section was simply gone like a magic trick. When they swage on ss fittings it looks much better and is much stronger.
Yes, hydraulic swagers have a lot of force behind them.
If any one has a pic of the results of the hand crimpers you are talking about I would like to see it or if there's possibly a link. Are they for crimping steel or just aluminim?
You can't generally hand crimp 1x19 stainless steel rope since it really isn't that flexible above say 3/16" or so—and can't be bent safely to use a crimp terminal to form an eye. If you're going to be hand crimping the wire rope, using nicopress terminals, you'd be much better off with 7x19 or 7x7, which is more flexible. However, I think you're far better off either getting the terminals swaged or using mechanical terminals, like the Hayn HiMod, Norseman or StaLock.
Saildog I think the HD ss cable was 1x19. The 19 means 19 strands right? What does the 1 mean?
1x19 cable is 1 strand made up of 19 wires.
7x7 cable is made up of 7 smaller strands consisting of 7 wires each.
7x19 cable is made up of 7 smaller strands consisting of 19 wires each.
These are the most common for wire rope on boats, but you may sometimes see 6x7, 6x19, or some other combination. IIRC, the more strands and the more wires per strand, generally the more fatigue resistant and flexible the cable is, to a point. However, IIRC, the finer the individual wires are, the more likely it is to meathook, since the individual wires are weaker.
Life's a bitch that way.
Then there is Dyform cable, which is technically a 1x19 cable, but the individual strands are shaped to create a wire rope that has less "air space" in it, and the wires are not uniform in size or shape. Dyform cable is heavier, stronger and stiffer than regular 1x19 due to this.
Basically, the first number is the number of strands per cable, and the second number is the number of individual wires per strand.
I hope this helps.
