Holly & Teak floor laminent
35
Freedom 21 Forked River, NJ
I have to replace the floor leading to the port aft berth on my 1984 h31 due to a leak. Does anyone have a lead on getting replacement Holly & Teak laminent that is used on the Marine Plywood? Has anyone replace the plywood with planking instead? How does it hold up and look?
Dec 2, 1999
15,184
Check out a product like Loncoin
Check out a product like Loncoin. I believe that it is make by Pirelli Tires. This product can be glued down with spray contact cement. It is very durable and is much easier than dealing with teak/holly again.
Rick D
Jun 14, 2008
7,206
Another Option
See this thread too. RD
F
Fred
Try sanding it first. It might clean up
better than you think. If it stays dark, try one of the teak brighteners. Another approach is to paint it with a good grade of alkyd porch and floor enamel with a bit of nonskid in it.
Barry Rogers
Call Teak Decking Systems in Florida
Teak Decking Systems in Florida manufacture teak decks and teak floors for large vessels. They have a consumer shop out front that sells teak and teak plywood panels in smaller than 4 x 8 sizes. Call them and ask for Chuck (Manager). He might be able to help you. You can reach them at 1-941-755- 5887. They are in Sarasota, FL Email them at www.teackdecking.com
Feb 9, 2007
35
Sanded It
I took a Belt sander to the floor and it came up beautiful. I then covered it with a clear coat and am good to go. Thanks for all your inputs.
