Its a 1997 hunter 376. I have stink water coming up into the glassed in basin located under the cabin sole floor panel just aft of the bilge and forward of the engine thru hull panel. Frequently when we boarded after an absence there would be stinky water pooling in the basin under that floor board. I used a hand pump to remove. There is a glassed hole at the bottom that doesn’t connect to the bilge.
I’ve since discovered that the aft portion of the keel is a hollow fairing and grinding out a weep hole in the keel in that location that the same stinky water was coming out. Back up in the cabin, stuck a coat hanger down the hole and, yep, its deep enough to go into the keel and the wire came up with the same stink water. Conclusion, the hollow keel vents up under the cabin sole. You ever have this issue?
Appreciate your thoughts. Plug the hole and leave the water? Find a way to drain/pump out? Live with it?
