John Coleman
Hi PeggyI have a H37C and I was wondering if I could use a storage compartment in the vee-berth as a holding tank. Two sides and the bottom of the tank would be the hull of the boat and the other two sides would be exsisting fiberglass bulkheads. The top is fiberglass as well but would have to be fitted with a proper cover. The shape of the tank could drain easily at the bottom of a bulkhead.Venting would also be straight forward. It has obvious advantages but what are the downsides?Thank you for all your help.JohnS/V Slainte1983 H37C
