holding tanks S2 8.5
Aug 31, 2014
1
s2 8.5 toronto
Hi,Replacing porta potty. Any advice on where to put the holding tank? The water tank has been removed and a bladder replaced it...could put both tanks under the vberth ???
Sep 18, 2014
3
S-2 8.6 San Diego, CA
I've got an 8.6, which is the same hull, deck, etc., with a little different interior layout. On my boat the starboard settee slides out to make a double berth; under the slide out there are two access hatches, and the holding tank is under the aft hatch.
Jan 14, 2015
18
S2 8.5 meter Plymouth
I just bought an 8.5 and I'm installing a Sealand 711- M28. The tank is 9.5 gallons and it fits perfectly in the existing space. I added a three way valve with a pump out and a maceration pump and overboard discharge. There was just not enough room to fit a tank under the seats.
