Holding Tank
Pete Pasquake
I've just purchased a C30 with what appears to be the original holding tank under to port side sette. Does anyone know the capacity of the tank?
C
C Jensen
I have a 81 c-30 and it holds about 20 galions. You will know when it's full, just look out the head window and you will see a stream of poo flowing down the deck! The tank vent is at the base of the stanchon.
Peggie Hall/HeadMistress
You're joking, right?
You don't REALLY ignore the tank level till it overflows...'cuz that's guaranteed to plug your vent line or the thru-hull sooner or later. Nothing should ever pass through a holding tank vent line but air.
