Screen shouldn't stop use of a snake...
Best thing you can do is knock it out, 'cuz screens become corroded by waste spills and get clogged up with dust pollen and air pollution.I dunno whether it's "bated" or "baited" either...but I'm just as eager as you are to find out whether the tank can be emptied if he removes the vent line. Best case, it can...worst case, he'll just prove me wrong. Yep, Randy...There is indeed a LOT to recommend a "pumpable" portapotty. J.C., there was no "6th sense" at work. And if Bobcat can't get the tank to empty even with the vent line off the tank, I WON'T be right about his problem. I just remember to ask more questions than most people do before giving advice...and Bobcat hadn't said WHERE the tank discharge is. But even if he doesn't have a pickup tube, a lot people read what all of us write...so your post wasn't wasted...somebody who does have a pickup tube will remember your advice.There can be other issues with pickup tubes too: they can be cut too short...and sometimes they fall out of the fitting.
