Bladders ok for water, fuel, but not for waste
The very "features" that make them attractive also make them all but impossible to keep odor-free--at least insofar as odor out the vent is concerned. And while water and diesel can be held in unvented tanks, waste cannot...because methane is flammable, CG regs require that all waste holding tanks be vented to the outside of the boat. Another consideration is, water and fuel tanks start out full and are gradually emptied...while waste tanks start out empty and are gradually filled. This means that a water or fuel tank isn't likely to become pressurized and blow out a fitting (and even if water tank does, it's ONLY water), but blocked holding tank vents are all too common and often do result in a pressurized tank...and bladders are highly prone to blowing out a fitting when even slightly pressurized.Taking all that into account, bladders are an ok choice for water, but a bad choice for waste holding.
