Mike Elmore
all,has anyone replaced their holding tank? I imagine most Catalina's have oddly shaped holding tanks (read not nearly square) like my C28 as they try to get them as big as possible out of the way. I want to replace my black tank with opaque poly(won't even try to spell it). I have no inspection port and would rather just be able to sneak a look to see if it's getting full rather than holing a port into it and adding a tank monitor.The size is just so wierd. it's under the port seat and is 11" high on the cabin side and 4" high on the hull side tapered between the 2 heights to fit into the hole.Any idea where I can get a new one sized correctly?Mike ElmoreWindward Hull-C28 Hull #7
